Stellarium 0.13.3 ist da !!
Hallo Sternenfreunde,
wieder mal ein großes Update bei Stellarium:
Stellarium 0.13.3 is a stable version that introduces some new features and closes 33 bug and wishlist reports. A lot of work has been done on adding few new DSO catalogs: Barnard (B), Van den Bergh (VdB), Sharpless (Sh 2), H-α emission regions in the Southern Milky Way (RCW), Lynds' Catalogue of Bright Nebulae (LBN), Lynds' Catalogue of Dark Nebulae (LDN), Collinder (Cr) and Melotte (Mel). In addition, two new plugins are available. One of them introduces an exclusive and very nice feature - 3D landscapes.
A huge thanks to the people who helped us a lot by reporting bugs!
We updated the configuration file and the Solar System file, so if you have an existing Stellarium installation, we strongly recommend to reset the settings after you install the new version (in the Installer).
Full list of changes:
- Added Scenery3D plugin: enable support 3D landscapes
- Added ArchaeoLines plugin: a tool for archaeo-/ethnoastronomical alignment studies
- Added new DSO catalogs: Barnard (B), Van den Bergh (VdB), Sharpless (Sh 2), H-α emission regions in the Southern Milky Way (RCW), Lynds' Catalogue of Bright Nebulae (LBN), Lynds' Catalogue of Dark Nebulae (LDN), Collinder (Cr) and Melotte (Mel)
- Added tiny visual improvements for info about comets and minor planets
- Added Hungarian translation for Aztec skyculture
- Added Russian translation for Western: H.A. Rey skyculture
- Added support of meteors for Windows/MSVC packages
- Added patch for multiscreen setups
- Added tui/tui_font_color option for change color of text user interface (LP: #1421998)
- Added new version of GCVS
- Added implementation of polinomial approximation of time period 1620-2013 for DeltaT by M. Khalid, Mariam Sultana and Faheem Zaidi (2014); http://dx.doi.org/10.1155/2014/480964
- Added new line on the celestial sphere - opposition/conjunction longitude (LP: #1377606)
- Added texture for Ceres (LP: #1271380)
- Extended list of proper names for deep-sky objects
- Fixed position of Great Red Spot (LP: #490019)
- Fixed bug in planet shadow shasder (LP: #1405353)
- Fixed flickering Moon problem (LP: #1411958)
- Fixed jittering moons (LP: #1416824)
- Fixed visibility objects on distance over 50 AU. (LP: #1413381)
- Updated the Spherical projection to be HiDPI aware. (LP: #1385367)
- Restore unit testing for refraction and extinction. Fixed issue in unit test for DeltaT and fixed small issue for DeltaT.
- Fixed issue in core.setObserverLocation (to a new Planet travels always 1 second) (LP: #1414463)
- Fixed issue for cursor, who points to a wrong position after orbit update (LP: #1414824)
- Fixed ignore the Enter key for online search dialog within Solar System Editor plugin (LP: #1414814)
- Fixed package issue for Windows XP (LP: #1414233)
- Fixed crash when trying to select a satellite with invalid orbit (LP: #1307357)
- Check of updates has been removed (LP: #1414451)
- Fixed issues in Search Tool (LP: #1416830)
- Fixed code to update ConfigurationDialog size (LP: #995107)
- Behavior of JD/MJD has been refactored for Date and Time Dialog (LP: #1417619)
- Avoid delaying for the telescope control slew commands over TCP (LP: #1418375)
- Avoid crash when clicking 'Lookup locations on network' checkbox in Locations window (Debian: #779046)
- Updated bookmarks for Solar System editor plug-in (LP: #1425626)
- Allowing display the scope marker below the landscape (LP: #1426441)
- Allow fading of the landscapes without atmosphere (LP: #1420741)
- Allow change thickness of lines of the constellations (LP: #1028432)
LG+CS
Peter
LG+CS
Peter
Canon 1000D, HEQ5-PRO
Schwerkraft nein Danke !
Re: Stellarium 0.13.3 ist da !!
Super, danke für die Info!
Kurze Frage noch zur alten Version. Der NGC2244 wird "Kugelsternhaufen" genannt, ist doch ein Bug oder?
LG Herbert
LG Herbert
LG Herbert
Celestron C6
Sky-Watcher AZ4
Berlebach Report 272
Celestron C6
Sky-Watcher AZ4
Super, Danke für die Info!, freue kcih auf die neueste Version
Hmm, wie kann man die lästigen VDB und LDN ausblenden?
Hat zwar schon jemand gefragt, offenbar geht das, aber nur wie?
http://sourceforge.net/p/stellarium/dis ... /?limit=25
LG Herbert
LG Herbert
LG Herbert
Celestron C6
Sky-Watcher AZ4
Celestron C6
Sky-Watcher AZ4
- Rev.Antun
Geh einfach am pc in das Stellarium Verzeichnis unter "nebulae" -> "default" und such nach LDNCat_tabbed bzw der zweite VDB sollte der VandenBerghCat_tabbed sein.
Verschieb diese beiden datein wo anders hin und schau mal ob es dann gelöst ist - sollte es einfachere lösungen geben bitte um info - danke.
wenn so gelöst kannst die datein dann auch löschen
Genial! Ich hab einmal alle Nebulae-Kataloge rausgeschmissen, bisher geht mir nichts ab, danke!
LG Herbert
LG Herbert
LG Herbert
Celestron C6
Sky-Watcher AZ4
Celestron C6
Sky-Watcher AZ4
- Rev.Antun
Bitte gerne - bei den EDV & Elektronik dingen die unser hobby betriffen kann ich derzeit meist mehr helfen ...
bei allen anderen dingen muss ich noch sehr viel fragen - bin ja erst seit herbst 2013 aktiv - aber schon genug gelernt
Also bei mir funktioniert die neue Version nicht auf dem Laptop.
Die Leiste unten sieht man nur bos zur hälfte.
Wenn man irgendwas anklickt kommt
ein schwarzes Bild und hängt sich dann komplett auf.
- Rev.Antun
was für ein laptop, welche grafikkarte/unterstützung und welche auflösung hast du eingestellt?
kommt eine fehlermeldung?
geb dir dann so schnell ich kann eine atw, oder ev schon eine lösung
ich habs auf einem uralt sony vaio PCG-7V1M der nur mit 2GB ram ausgestattet ist am laufen, hab gleich den laptop komplett neu installiert für astrozwecke
Ist ein Sony Vaio VGN-NW21MF mit einer ATI Grafikkarte.
Grafikkartenupdate musste ich für Stellarium bei zwei meiner Rechner machen, der Fehler zeigte sich aber nur in unten abgeschnittene Fonts.
Vielleicht einmal die neuesten Treiber Deiner Grafikkarte im Netz suchen und installieren.
LG Herbert
Celestron C6
Sky-Watcher AZ4
Celestron C6
Sky-Watcher AZ4
- Rev.Antun
openGL auch aktuell ?
Phhhuu das fragst Du mich zuviel Toni
Ich werd mal einen Treiber Update machen
Vielleicht klappts ja dann.
