Unter den denkbar schlechtesten Bedingungen, bissl Wolken und so
Firecapture & Fitswork - nicht viel herumgespielt.
FireCapture v2.5 Settings
Camera=ZWO ASI120MM
Filter=L
Profile=Mars
Diameter=3.68"
Magnitude=1.83
CM=354.8° (during mid of capture)
FocalLength=167550mm
Resolution=0.00"
Filename=Mars_234848.zip
Date=021017
Start=234848.467
Mid=234952.319
End=235056.171
Start(UT)=214848.467
Mid(UT)=214952.319
End(UT)=215056.171
Duration=127.704s
Date_format=ddMMyy
Time_format=HHmmss
LT=UT +1h
Frames captured=1000
File type=FIT
Binning=no
ROI=1280x960
ROI(Offset)=0x0
FPS (avg.)=7
Shutter=1.020ms
Gain=19 (19%)
SoftwareGain=10 (off)
AutoExposure=off
Brightness=16
HighSpeed=off
AutoHisto=75 (off)
USBTraffic=90
Gamma=44
Histogramm(min)=0
Histogramm(max)=4064
Histogramm=99%
Noise(avg.deviation)=n/a
Limit=1000 Bilder
Sensor temperature=14.0 °C
