Hallo Sternenfreunde
wieder mal ein großes Update bei Stellarium.
Link: http://stellarium.org/release/2017/12/2 ... .17.0.html
Ich benütze gerne die portable Version unter
https://portableapps.com/news/2017-12-2 ... 0-released
Version 0.17.0 is based on Qt 5.9.3, but it can still be built from sources with Qt 5.4.
The major changes of this version:
    Added support for nomenclature of planetary surface (SOCIS 2017 project)
    Added improvements for AstroCalc tool
    Added improvements for Oculars plugin
    Added improvements for Exoplanets plugin
    Added INDI support for Telescope Control plugin
    Updated code and data
A huge thanks to the people who helped us a lot by reporting bugs!
Full list of changes:
    Added templates for translation of planetary features nomenclature
    Added support of movement to selected nomenclature item
    Added new tab for AstroCalc tool: Planetary Calculator
    Added Icelandic translation for a couple of skycultures
    Added another OS detection logging function
    Added new landscape: the Sun
    Added Russian translation for new landscape
    Added filters for nomenclature (Search Tool/Lists)
    Added support plural forms for translation (LP: #1561457)
    Added deselectConstellations() method to public area
    Added new time steps for AstroCalc/Ephemerides tool
    Added sane defaults to Planets
    Added subclasses to the list of Solar system objects in AstroCalc/Positions tool
    Added config option to allow make visible orbits for major planets only (LP: #1720722)
    Added rule to allow to hide nomenclature on the celestial body of observer (LP: #1723742)
    Added context support for Solar system bodies
    Added angular size filter for DSO
    Added shortcut for nomenclature
    Added plus/minus keys for elevation change on Macs without PgUp/PgDn
    Added better font scaling for HiDPI Macs
    Added detection method info for exoplanets
    Added visual resolution info for Oculars plugin
    Added GUI options for color of exoplanet marker
    Added a default for night mode
    Added API command to retrieve view direction in RemoteControl plugin
    Added API commands into RemoteControl plugin: allow view setting jNow, harmonize capitalisation for the parameters.
    Added velocity display to Planets, MinorPlanets and Comets
    Added improvements for AstroCalc/PC tool
    Added orbital velocities for AstroCalc/PC tool
    Added special case for long list of “also known as” names
    Added Caucasian Mountain Observatory to locations list
    Added option to select temperature scale to the Exoplanets plugin
    Added option to allow scaling of Ocular buttons (LP: #1507205)
    Added new option to the Navigational Stars plugin
    Added checkboxes for DSO catalogs (PN G, SNR G, ACO) in Remote Control plugin
    Added wikilinks for names of Solar system bodies
    Fixed filter for limiting by DSO mangitudes
    Fixed TestStelJsonParser fails (LP: #1719076)
    Fixes and additions for French descriptions
    Fixed context support for constellations
    Fixed sort order for ‘Peak’ in Meteor showers search (LP: #1719939)
    Fixed location for stellarium.appdata.xml file
    Fixed stupid bug for asterisms in Search Tool/Lists
    Fixed some back-side issues of nomenclature (LP: #1721815)
    Fixed crash for Custom Objects (LP: #1722527)
    Fixed output data for Exoplanets plugin
    Fixed potential crash for nomenclature and inconsistency of data
    Fixed light speed correction issue for nomenclature items (LP: #1724517)
    Fixed annoying malfunction in Oculars plugin (lost of tracking) (LP: #1724106)
    Fixed the new moons’ rotation times
    Fixed selecting of comets in AstroCalc/Positions tool
    Fixed behaviour and style of tool for download star catalog
    Fixed infostring for satellite features
    Fixed centering/tracking issues for Nomenclature feature (LP: #1721818)
    Fixed small Coverity issue
    Fixed bug of positions for nomenclature when Solar system data is reloaded
    Fixed shader for planet texture rendering (LP: #1731788)
    Fixed sign for declination coordinate for Southern Iota Aquarids
    Fixed behaviour of Velocity checkbox
    Fixed Oculars GUI Panel behaviour: disabled event processing on the sky under GUI
    Fixed ray helpers lines behaviour in Oculars plugin
    Fixed crossid info of alpha2 centauri (LP: #1734396)
    Fixed Oculars plugin mouse bug on retina display
    Fixed wrong unit of measurement for distance
    Fixed mouse cursor hidding
    Fixed zero-filled initial date/time window issue (LP: #1409935)
    Fixed crash of Stellarium when flag for decimal degrees usage is changed
    Fixed regressions introduced by recent LabelMgr refactoring
    Updated default settings of build environment for Windows and Mac OS X
    Updated ICU rules for Qt 5.9+
    Updated Oculars plugin (Allows accessing via RemoteControl)
    Updated list of DSO outlines (port from HNSKY)
    Updated list of DSO names
    Updated behaviour of auto-load landscape when moving to selected planet
    Updated scripts and their descriptions
    Updated Bengali description of landscapes
    Updated list of planetary nomenclature
    Updated list of official star names
    Updated default time step for AstroCalc/Phenomena tool
    Updated behaviour of flag for orbits to renew visibility of orbits
    Updated GUI items in the View dialog
    Updated list of ray helpers
    Updated protocols for MPC
    Updated Triangulum constellation lines
    Updated the solar system screen saver script
    Updated code for beta versions naming
    Updated Chinese skyculture
    Improved performance for AstroCalc tool
    Improved performance for Nomenclature feature
    Code refactoring
LG+CS
Peter
							Stellarium 0.17.0
Stellarium 0.17.0
Canon 1000D, HEQ5-PRO
Schwerkraft nein Danke !
