im trostlosen Winter habe ich mich ein wenig mit dem Hubble Legacy Archive beschäftigt.
Dort kann man sich alle möglichen Bilder von Hubble laden, zusammenfügen und bearbeiten. Die Daten sind in verschiedenen Levels erhältlich - Text aus den FAQ:
There are several levels of data in the HLA:
Level 1 data are the individual exposures, projected ("drizzled") onto a common frame for each visit.
Level 2 data are the combined images (exposures with the same filter, same camera, and within the same visit).
Level 3 images are deep combined images or mosaics creating by combining data taken in different visits to the target.
Level 4 data are false color images (a combination of two or three colors, depending on what is available). They are included with other selections to help users assess data quality.
Level 5 data are the community-contributed high-level science products (HLSP).
Level 0 (calibrated, unprocessed) are not available for direct searches but may often by found using the More... link.
The Advanced Search options can be used to select the level of data included and searches. The options also include All, which selects all level 1-5 data, and Best Available, which selects the data product that is generally the most useful (e.g., the combined image or HLSP product if it exists, rather than the single exposure or color image). Currently the Best Available list includes all image products of level 2 or above, and includes level 1 data only for exposures that are not used as part of level 2 or 3 products. However, there are cases where it is useful to set the level manually using the "advanced search" option, for example to diagnose why the combined image looks unusual, by selecting exposures (level 1) or All.
Viele Bilder von etwas größeren Objekten sind nur als Mosaike erhältlich - Hubble hat ja etwa 57m Brennweite. Da heißt es suchen...
Nun zur kurzen Anleitung:
Nachdem man auf die Seite gelangt ist, kann man nach einem Objekt suchen (hier Ngc 4217, die kleine Edge-on Galaxie rechts unter M106):
Die interessanteste Kamera ist die WSPCS2 (bzw. alle WS Kameras). Die Filter sind nicht mit LRGB oder sonstwie beschriftet, sondern nach Wellenlänge!
Im Beispiel oben würde man daher das 2., 4. und 6. Bild wählen. "F450W" ist blau, "F555W" ist grün, "F814W" ist rot. Natürlich haben Hubbles Instrumente andere Empfindlichkeit in anderen Spektralbereichen, aber diese Zuordnung passt. Bei Nebeln ist es dann noch interessant, sich Bilder mit ganz anderen Wellenlängen zu suchen und zu kombinieren.
Passende Bilder gibt man in den "Warenkorb", indem man den Link in der dritten Spalte klickt (Einkaufswagerl fits):
Und so schaut der Einkaufskorb dann aus:
Man kann sich hier also nach Lust und Laune bereits fast fertige Bilder oder aber auch harte Nüsse laden und Spaß haben. Bei einer Veröffentlichung würde ich halt "Hubble Legacy Archive" als Credit angeben!
